FamilyWiggs
- Flintshire, N Wales.
:shock: Well, I say he deserves a pass, with merit, distinction and a PPUK Kitkat!FamilyWiggs said:it was done by hand very slowly. He hadn't completed his exams at this point...
worms said::shock: Well, I say he deserves a pass, with merit, distinction and a PPUK Kitkat!FamilyWiggs said:it was done by hand very slowly. He hadn't completed his exams at this point...
Ooh, picky!middi said:Whilst the repair is excellent, the perfect repair should have incorporated a " square oak peg" 2" x 2", countersunk 1" into the old beam and 1" into the repair section midway in the length of the spliced joint and clamped toghether normally with S/S bolts .
The bolt heads inserted into heavy duty square washers countersunk into the beams and covered with square pegs. This, done correctly, would have eliminated the need for steel plates and the "sliding apart" action woul have been stopped by the square peg.
At present the bolts are clamping the sections toghether and the joint is kept from sliding apart by the steel plates, but visible. Nothing wrong with the structural stability of the repair and , generally, 10 out of 10 for the repair, but, 8 out of 10 from an aesthetic point of view
Middi
LadyArowana said:Definately, although I might need a word with Mr Wiggs about textile conservation/ display based on what I can see hanging up in the picture :roll:
I should have thought that was obvious. After all, you wouldn't bolt your washing to the line, would you?*FamilyWiggs said:would thus have asked for pegs not bolts
JanJonWestWales said:how do i add photos???
Check my post ( heading , beam end replacement) hope it helpsHi, we are contemplating replacing the main oak beam in one of the rooms in our Welsh farmhouse. It is 12"x12"x15' and is hand hewn (original hewing marks), a shame that the ends have rotted away and are being supported with iron braces at one end and a supporting post at the other.
I am loathed to take it out as it is gorgous and probabaly older than the house (1758). But have decided to fit a new(or reclaimed) beam.
Any advice on new/reclaimed beams, and what to do with the old one, i want it to go to a good home. Ive been trying to think where else i can use it, but nothing is really suitable. Cut down to size it will be 12"x12"x 13'.
Any takers??
J&J
