Toby Newell
- Surrey
Sill plate? How old is your house? Do you mean sill plate as in beam construction and sill beam is supporting wall uprights? Or do you simply mean seat beam as in beam that simply supports the floor joists?
If your house is brick construction then removing your seat beam and replacing the entire subfloor is not a problem, although it may be necessary to replace the pier walls as often in these chronic damp cases the mortar and even the bricks themselves effectively 'rot' and crumble.
I would ask a surveyor to check exactly what load these 'beams' carry.
All modern timber C16, C24 or otherwise are normally PAR (Planed All Round) or regularised (same thing) and often eased edge (rounded edge) nominal dimensions are usually 45x95 cf. 50x100mm + for rough sawn old 'four by twos'.
You can make up any difference by either stacking slate on top of the piers (traditional) or using plastic shims (modern) If you are rebuilding the piers 5mm is quite easy to accrue with mortar over the stack with careful tamping. In any event nothing will be 100% level and I personally level each joist I lay with shims, both plastic and wooden that I cut myself.
Bear in mind that your skirting will have moved with your house over time, so, no matter how diligently you level both the sub and top floor your skirting may still be wavy! Like it or not this is the inevitable 'charm' inherent in older buildings.
If you have money to burn or just enjoy a challenge, you can remove all your skirting and scribe it in for a closer fit, although I would leave it a few months, possibly a whole year, for the new floor to settle.
If it makes you feel any better, I would like to see how the 'Barret' home generation of modern buildings fare in a 100 years time, I am not convinced they will be fairing much better!
