Westholme
- Gloucestershire
I forgot to say that an old OS map should give you some idea how far the scullery extended, if that is not clear. 1:2500 maps are available free online.
Westholme said:.........The join between house and conservatory looks to be a real bodge job.
Westholme said:I think the span between the side walls is more likely to be eight feet. In view of the movement of the house, I suggest restoring what was removed, i.e. imperial size bricks and lime mortar. Assuming you have a solid 9" wall, adding 1½ / 2 / 2½ bricks either side would reduce the span by about 2 / 3 / 4 feet.
The new lintel could be an inverted T steel lintel, e.g. Stressline SL200 'T'. As everything was taken out up to the ceiling, it and most of the new brickwork could be installed without affecting the existing beam. Once the latter and the brickwork above and below it have been been exposed, you should be able to see for yourself what needs doing.
Greenwoods said:.........I'd like to do a lime mortar and imperial size bricks job, but would I get away with concrete blocks/standard mortar here, do you think? ........
MikeG said:Greenwoods said:.........I'd like to do a lime mortar and imperial size bricks job, but would I get away with concrete blocks/standard mortar here, do you think? ........
You appear to be ignoring advice. I'll say it for the last time: you need a structural engineer to look at this. This opening is not something that you should be playing with on an ad hoc basis. I don't want to be scaremongering but you have a potential building failure or collapse on your hands. I'm an architect, as I said before, and you should be taking the advice you've been given urgently.
You appear to be ignoring advice. I'll say it for the last time: you need a structural engineer to look at this. This opening is not something that you should be playing with on an ad hoc basis. I don't want to be scaremongering but you have a potential building failure or collapse on your hands. I'm an architect, as I said before, and you should be taking the advice you've been given, urgently.
MikeG said:I don't want to be scaremongering but you have a potential building failure or collapse on your hands. I'm an architect, as I said before, and you should be taking the advice you've been given, urgently.
