Cubist
More perishing zoo animals. Well at least it's not an elephant this time.Or a rhinoceros!
Zoo??!! Take that back, sir! I'll have you know we are free animals from the African Savannah!More perishing zoo animals. Well at least it's not an elephant this time.
That looks amazing, full compliments to the plasterer! Best of luck for the final coat.View attachment 10173
3rd and final coat going up today. Plasterer has used best of lime ready mixed product throughout and advised that it should be fine to paint after 4 weeks provided a very breathable paint is used.
I have read a lot of people on here saying to wait 3-6 months or 1 week per mm (there’s about 15mm here). Aparently best of lime product cures faster and I suspect it helps being a ceiling in that it can breath 2 directions (unlike solid walls which will mainly breath into your room).
Anyone agree that I should be fine to go ahead after a few weeks.. also was planning on F&B estate emulsion with an SD value of 0.010 however I have seen people recommend their casein distemper with an SD value of 0.008. The improved breathability seems minimal, is it really worth it?
They are doing a very major refurbishment, so all new wiring for everything to be upgraded, lots of chasing in, you name it, plus all the twiddly bits like light fixtures, carpets. It’s already costing loads of money, so even split between everyone ( two mansion blocks, one freehold ) it’s fairly serious. They have discovered a few surprises, which aren’t actually that much of a surprise to me, but of course were not in the initial budget. So it’s a case of take down unsafe ceiling and replace with plasterboard and make it look nice. We aren’t listed.@LadyArowana What are they doing with your communal hallway? Just standard plasterboard? Does seem a shame especially when the increased cost could likely be shared among many.
That’s a good idea @RBailey . Can limewash be used as the final coat? The whole room is being decorated so would be nice to get ceiling done before doing walls and woodwork to prevent any unwanted speckles etc.
People plasterboard over lath & plaster ceilings all the time, it should be fine as long as the joists can take the extra weight. A perfectionist might prefer to remove the remaining lath & plaster before applying the plaster board but its a dirty job and you lose the excellent sound proofing of the old lath & plaster.@MatthewC thanks for this. The two rooms are an upstairs bedroom and the sitting room below it. My preferred option is for the reinstatement of original lath & plaster ceilings and/or just repair the damaged bits if possible. Original fabric of house and in keeping etc,
However, If the insurers refuse to go down that route because of betterment etc , ithen it is a case of remove existing ceilings and replace with plasterboard vs keep damaged original ceiling and stick up plasterboard underneath it. It seems you are recommending the latter option? With the sitting room ceiling could that "space" between the plasterboard and the old ceiling be a nursery for mould and rot?
