I like the idea of not having to route out part of the sash as with the grabba , but I can’t get the cord through the slot in the grippa (I have right diameter). Any tips?Mighton Cord Grippa works perfectly well for me. No modification needed to the sash. Give it a squeeze with big pliers to make sure it attaches firmly to the cord.
I guess for me I like the following.Can anyone enlighten me why the Cord Grippa makes life easier? When I re-cord my sashes I just knock in a couple of nails to hold it. Takes less than a minute, and in the unlikely event I need to remove the cord within my lifetime (nylon core and cotton outer, so won't snap), it just needs a pair of pliers.
I'm a big fan of widgets that make life easier, but don't see the benefit here. What am I missing?
Thanks Mart, makes senseI guess for me I like the following.
1. They allow the windows to be easily removed after fitting, I've had to do this once so far so rare but easy.
2. Actually fitting is very quick with no need to hammer in nails whilst holding a sash and the cord in place.
3. They are predictable, each window is the same with no variables that would come with hammering 4-6 nails per sash.
They're also really cheap so not like a huge cost. I think they just make the process ever so slightly easier overall.
Yes, with the idea that the cold air would blow the flap open and close any gap. It does seems to work like that... You need some ventilation and I like to think this might be just the right amount for a room where no cooking or laundry is carried out.I like that approach Stevers - think I might follow suit on the windows that I'm not going to get around to this year before winter sets in. From your photo it looks like you have the "V" facing towards the frame?
MartAnother couple done, finally tackled the one I was worried about. After cleaning up the rot I decided to go with the 2 part resin to repair. Turned out very well indeed, its amazing how far gone a window can be and still repaired.
Historical repairs mean I couldn't run the parting bead as low as I'd like.
I'm suspecting the damage was mainly due to a gutter leak and overgrow plant but will be keeping a close eye on this window over the winter.
View attachment 11489View attachment 11491View attachment 11492View attachment 11490View attachment 11493View attachment 11494View attachment 11495
I have a chop saw, would be interested to hear how i could make a bottom rail with one. I can imagine how you'd cut the tenons but not the sloped bottom.That's a lot of wood to replace with resin. You only need a chop saw to make a new bottom rail and scarf in repairs to the uprights and have an all wood window. Wood is always trying to find ways to let water out and the water will tend to build up at the join to the resin.
Having said that I have a bay window where the sill has been replaced with concrete sill and I've no intention to make it wood as it works well enough as it is.
Oxera repair - really impressed with it so far and keenly priced. The 4 hour rebuild resin comes in useful pots.Mart
What type/brand of Resin are you using
I have a chop saw, would be interested to hear how i could make a bottom rail with one. I can imagine how you'd cut the tenons but not the sloped bottom.Oxera - thanks
It's early days but I'm happy with Oxera.Oxera - thanks
I have a bottom rail (re)-repair to do...
It was in bad shape and had warped - so even with splicing timber and filling it (Hand Up - I used Ronseal 2 part) ; its cracked
(Its south facing and bears to full brunt of the Sun)
I'm tempted to do one more repair - and use a Top Tier Resin, but had also considered a new bottom rail altogether
I haven't checked whether this is the right size etc - but more a point of showing these type of things exist
Sash Window – Meranti Sash Bottom Rail 44 x 95mm x various lengths | Chiltern Timber
www.chilterntimber.co.uk
