We are in the process of purchasing two attached cottages - one of which is a late medieval timber framed single storey cottage (Grade II listed- 2 up 2 down).
The timber frame is exposed on one gable wall. The exposed frame (west facing) is water damaged and has been badly repaired with cement render. The infils are brick and in some places cement rendered.
The remainder of the house and timber frame is covered by a cement based roughcast. (We are planning to strip this off and replace it with a lime based render/roughcast to help the house breathe).
Today we had a full buildings survey performed by a historic building consultant/surveyor (experienced in timber framed houses). We were expecting to employ professionals to repair the gable end by removing the damaged timber and splicing in new, as well as relacing the sole plate, however we were hoping that as the house was stable the remainder of the frame under ths render would be in better shape (minor replacement).
However our surveyor is of the opinion that the roof (will need replacing in the future anyway) will need to be removed, all the infills removed as well as all other remaining materials, leaving only the timber frame. He would then suggest having the sole plate replaced and underpinned. Basically removing everything except the timber frame. Our purchase price would represent a very expensive damaged timber frame!
My question is, as the timber frame is predominately covered, is our surveyor looking at the worst case scenario or is taking the frame back to this level normal in a house of this age?
We want to renovate the house symathetically and retain as many original materials as possible.
If there are any timber frame professionals out there who can shed some light on the likely costs or provide any assistance it would be greatly appreciated.
