paulbandler
- Oxfordshire
I've read with interest the extensive advice on this forum and elsewhere about the merits of reinstating lime plaster in old properties.
I am in the midst of renovating a 1920's modest cottage and have removed quite a lot of blown lime plaster on ground and first floor and have been considering reinstating with lime. There was some rising damp on the ground floor that I hope have addressed by removing external render where it breached the DPC. However it is not feasible to remove the remainder of the render that I think it cement based and has been coated with tyrolean to give it a rough-cast finish. From what I've read this this outer coating would prevent the walls from 'breathing' as it was originally designed to before the render was applied right?
My question is then is given the 'cement/tyrolean' jacket on the outside of the property, is there any real merit in reinstating with lime plaster internally?
Thanks in advance for any advice.
