A
Anonymous
Guest
Hi,
I want to open up a fireplace which has been bricked up at some point in the past.
There is a brick arch which I would imagine was the original support for the fireplace opening, but it does not appear to be in the best condition. In particular, the edges (left and right) don't appear to be well supported to my untrained eye, as if the surrounding bricks have been hacked off a little. See pictures below:
http://homepages.nildram.co.uk/~whyard/chimney_arch.jpg
http://homepages.nildram.co.uk/~whyard/chimney_arch_left.jpg
http://homepages.nildram.co.uk/~whyard/chimney_arch_right.jpg
Further down, there is a relatively thin (about 2cm) metal bar running horizontally at about the height you would expect the fireplace opening to stop. See picture below (the bar is at the top):
http://homepages.nildram.co.uk/~whyard/chimney_metal.jpg
Which, if any, of these is providing the support for the stack? Does the brick arch look in good enough condition? I'd like to know where I can start removing bricks
Thanks for any help.
(Not sure why the colours are screwed on the photos!)
