Dave W
- Evesham, Worcestershire
Is it worth using stainless steel screws to alleviate rust concerns ?
Dave W said:Is it worth using stainless steel screws to alleviate rust concerns ?
What do you mean: "Trouble is..."? Buying tools is what the male was put on earth to do.88v8 said:Trouble is, one can just go on and on buying tools
It's also advisable to paint the back of the board as well as the front, to give a balancing effect.Andrew Bodenham said:I'd put a layer of polythene behind the skirting to stop it from cupping / eventually rotting.
plasticpigeon said:Experts???
Yes what you are suggesting sounds like the normal way to fix skirting. It might be good to affix a wooden spacer where you screw so that the skirting when screwed tight is level with the plaster (I assume that the plaster doesn't go all the way to the floor). The traditional way was to rake out some vertical mortar joints at regular intervals, hammer wooden wedges in, cut the wedges level with the plasterwork and then nail the skirting to the wedges. It is not a bad way of doing things, but drilling and screwing is easier and just as good in my opinion.
