biffvernon
- Lincolnshire
NT said:Start with a quote for the lam glass, you can cut it yourself into slates. NT
How do you cut laminated glass?
To answer your question if I may I believe that, while single sheet glass only requires one side scored, laminated glass requires both sides scored and a sharp knife to cut the laminated material.biffvernon said:NT said:Start with a quote for the lam glass, you can cut it yourself into slates. NT
NT said:yes, score both sides and snap, then bend to break the central plastic layer.
biffvernon said:NT said:yes, score both sides and snap, then bend to break the central plastic layer.
Yes, but have you tried? It's a pig. I'm not sure that, all things considered, it might not be better to use toughened. There's not much difference in price.
