JoceAndChris
- Lincolnshire
Hi dalivar. Your experience is identical to ours three years ago, and I suspect to many writing on here! I wouldn't worry too much about what's said by so-called professionals as so many of them seem to be a bunch of hopeful salesmen who just want your money. They won't live in the house and so they will never understand it. If you want the house, buy it, and trust to your own judgement about whether or not it's damp, and where it's damp, and what's the best thing to do to remedy that.
You'll find a lot of very valuable, helpful experience on this forum and I also recommend the SPAB website and "The Old House Handbook" by Marianne Suhr and Roger Hunt.
Cement render can be problematic, we're going to have ours removed and rerendered in breathable lime. That will be 25k. A cheaper alternative is to remove areas where damp is a problem and patch in lime.
You might also want to consider emoving the concrete ground floor and replacing it with breathable limecrete. That will be some more ££££ so bear ion mind that if you really want this house it might end up costing you a fair bit to sort the damp out. Or, it might be that you just fix up the guttering and the drains and you have no more problems.
But squirty chemicals are unlikely to do anything good to the building.Good luck, and do post back.
