johnandrew
- Halifax, West Yorkshire
Dear All
Have recently received the report of a structural survey on the stone built victorian house we are planning to buy.
I have my own ideas about how to go about things but wanted some reassurance from someone who has the experience that I don't have. Having failed to get that reassurance from the survey report, I am turning to you guys to give me the confidence that I am on the right lines.
Here we go then:
1.) The external ground levels seem a bit high (at or just below internal floor level). Some evidence of replaced ground floor joists in the timber suspended floor.
Surveyor says: There are air bricks but they give inadequate flow and are below ground level. They need to be replaced with modern ones and moved higher so they are not at ground level.
I say: Maybe more airbricks/vent are need but surely they don't need to be moved up. The ground level needs to be moved down.
2.) Pointing
Surveyor says: Evidence of repointing to some of the property in sand and cement. Original pointing also done with sand and cement
I say: Given the surveyor estimates the construction date to be 1860-1880 is it not likely that the original mortar is a sand and lime?
3.) Dampness (maybe you can all guess what is coming now)
Surveryor says: The walls were tested with a meter at ground level and we received very high readings. We think this is because of rising dampness and the lack of any apparent DPC. Advise you to get in member of BWPDPA to investigate further.
I say: Indeed there is dampness. The place smells musty, the paper is peeling from the walls, the plaster is all but hanging off. But, perhaps the DPC is hidden by the raised ground levels? Even if there isn't one, maybe we should consider reducing exterior ground levels, opening the fireplace, and ventilating the place.
Won't go on any more.
So, am I on the right track?
John Andrew
Here we go then:
2.) Pointing
John Andrew
