I hope no one minds me resurrecting this old topic, but I thought you might like to see what happened next . . .
After lengthy discussions with Terry, who has made plaster moulding for us before, we decided to get him to make plaster beaded corners for us rather than try to use wooden beads. This picture shows the construction detail. Because the plaster bead "embraces" the corner it can be made a larger diameter than a wooden staff bead, which would need some fancy machining to get the same effect. The bead has two flanges extended beyond the quirk to meet the plaster. The plaster float coat is run flush to the rebate and the joint covered with scrim tape and then the skim coat is run flush to the outside of the moulding. We are having the rooms traditionally wet plastered rather than dry lined.
Terry ran these on the bench in 3m lengths. You can see the larger bead, about 1.6" diameter, which makes the bead a visually more impressive feature when in place.
Charlie fixed the beads to the corners and then formed the birds beaks by hand in-situ.
This picture shows the beads around two of the doors, before the birds beaks were formed.
I hope someone finds this interesting!
Regards - Brogden
Regards - Brogden
