My understanding (which could be wrong) is that an RCD isn't required in some circuits if the cable is buried or shielded as above. It is required in some circuits - bathroom, kitchen and downstairs ring main comes to mind - could be wrong.Flyfisher said:Is an RCB not a requirement these days, whatever the wiring arrangement?MdB said:Make sure it is on a RCB before re-routing as hidden cable not on a RCB has to be buried by 50mm or enclosed in metal trunking.
Surely they're a good idea for all sort of reasons?
RCDs are a good idea, however, it is a bad idea to have a single RCD covering all circuits as it means that when something trips, all your lights go out. Some people therefore recommend that light circuits aren't on an RCD. Personally I think that using RCBOs is a better though more expensive option which is what I'm using. I also have the smoke alarm circuit and stair/hall light on its own RCBO. This way not all the upstairs lights can go out at once and I'll know quickly if the smoke alarm circuit has tripped.
(yes, I did call an RCD, an RCB above - I was thinking about RCBOs which are similar)
