Good question and I don't know the official answer. The idea is to stop people screwing a light fitting to that continently placed baton at the side of the room so following the new rules isn't a bad idea.Penners said:MdB - would those rules apply if you were boxing in existing cable runs?
I'm not suggesting you're wrong - just a genuine question.
It may be possible to get away with this if it on a 3A fuse.robgil said:my lighting circuit from what i can see is distribution blocks and i was hoping to use this cable from the switch to the box , i can hopefully hide the rest but at .75mm it wont meet regs anyway.
Make sure it is on a RCB before re-routing as hidden cable not on a RCB has to be buried by 50mm or enclosed in metal trunking.robgil said:i will certainly get a sparkys advice before using any none standard cable , this is what my gray cable looks like , some of this is for the ring main and i can hide a lot of it by re-routing it so its not all bad.
Is an RCB not a requirement these days, whatever the wiring arrangement?MdB said:Make sure it is on a RCB before re-routing as hidden cable not on a RCB has to be buried by 50mm or enclosed in metal trunking.
