MatthewC
- Central/South England
TobyToby Newell said:concrete is NOT impermeable which is the whole reason for the OP. Concrete if fully dried will come into equilibrium with its surroundings by absorbing or emitting water vapour. Air, concrete and wood have different water holding capacities for any fixed temperature and pressure in a closed system (like a well insulated house)
I'd like some clarification on this statement please, as at first glance it turns my world upside down. On this forum we often regard concrete and all other cement products as impermeable but I presume you are really saying that there are grades of impermeability? Limestone and lime putty products are (in my simplistic view) many times more permeable than cement products, and this is what allows an old house to breathe, whereas cement/gypsum trap the moisture in because of their (relative) impermeability. My own house, before and after restoration, is a good illustration of these principles and if I've misunderstood I'd like to know how it does work!
Also on this sort of subject, I'm unclear about the permeability of NHL and anything which uses hydrated lime. I suspect that these fit in the scale between lime putty mortar at one end and concrete at the other.
You seem to know a lot more than the rest of us about the science of this so could you please give us some more explanation of these principles?
Matthew
