IOW
- Isle of Wight
Hi, I’m new hear and just need your advice. I’ve just had all my Victorian villa sash window renovated sanded and now painted to a great expense in the Isle of Wight. In 4/5 months the paint has bubbled and cracked and not adhered to the wood. Mainly on the bottom of the sashes and the sills. For your information the painter did not strip the old paint off just sanded. I’ve had the painter back with his so called specialist friend and has told me the wood has no juice left in it and is dead. That’s why the paint he used (He says the best Weathershield 12 and 3 ) is not adhering to the wood. He also tells me that the old sashes at one point had been varnished so once again it makes painting old sashes hard because the varnish is in the grain. His out come would be to replace all the 32 windows. I was like that is not an option and need another opinion. That is why I’m turning to you guys for some well needed help. Is there a specialist product out there that I can use to paint the window with that will actually work on 100 year old windows. Just to also confirm that the Weathershield did work on the new replacement wood and sashes so I do see his point, but there must be a way to save my windows and paint the 100year old wood. Thank you in advance to professional advice.
