biffvernon
- Lincolnshire
The cross-headed stainless screws are a bit suspect.Penners said:Possibly not authentic to the age of the house
Not at all, you're absolutely right about them being a mess at present. I just wanted to be sure you knew why and that they are not representative of newly limewashed beams.JoceAndChris said:Your beam photo - wrong of me to judge when they're in a kind of halfway-house state.
Ever thought of taking up woodwork? If I can make curtains, you should be able to make kitchen units!JoceAndChris said:this will have to remain as kitchen porn I think
You really are a girl, aren't you?! :roll:JoceAndChris said:they have already been destined to be hidden, as of today, by a frilly, toning, strawberry-embroidered duck egg pelmet.
Joce subscribe to these guys...Nigel Watts said:Ever thought of taking up woodwork? If I can make curtains, you should be able to make kitchen units!JoceAndChris said:this will have to remain as kitchen porn I think
ilona73 said:Joce subscribe to these guys...
www.theusedkitchencompany.com
Nigel Watts said:Its not a great photo, and this piece of furniture would be better suited to a different kind of kitchen, but here is a glimpse of a cook's counter I made over 15 years ago
I had the modern kitchen units build around it. The design came from a book of furniture projects for amateurs by well known designers published c.1980. The designer in this case was Richard Latrobe Bateman. I have also made a dining table and stool in the same style.
Penners said:You really are a girl, aren't you?! :roll:JoceAndChris said:they have already been destined to be hidden, as of today, by a frilly, toning, strawberry-embroidered duck egg pelmet.
:wink:
The extent to which the limewash "blinds" the wood of the beams depends on how many coats you put on. The more coats, the more that the colour of the wood will disappear under the white.
And, tasteful though I'm sure your frilly, toning, strawberry-embroidered duck egg pelmet may be, it won't stop the beams, and the gaps between the beams, from shedding dust.
A true cabinet maker would feel just the same. Surfaces should be finished with a perfectly sharp and well-adjusted plane, and if any other smoothing is still needed it should be done with a cabinet scraper. Sanding dulls the surface and leaves grit in it.JoceAndChris said:using sand-paper gives me the absolute heebie-jeebies.
jocelyn plummer said:I suppose some might argue that the costs of pots of paint mount up,
jocelyn plummer said:B & Q have a 50% sale and their kitchen units are very good indeed, especially the cooke and lewis range
Nigel Watts said:A true cabinet maker would feel just the same. Surfaces should be finished with a perfectly sharp and well-adjusted plane, and if any other smoothing is still needed it should be done with a cabinet scraper. Sanding dulls the surface and leaves grit in it.
Moo said:http://www.theusedkitchencompany.com/ Whereabouts are they?
