Nemesis
- Planet Earth
Ah, Squirrels v birds. Well clearly the answer re wildlife conservation is to shoot the squirrels?
If by "should be" you mean "correct for the period of the house", then that's probably not the case. Softwood shutters would almost certainly have been painted, or wood-grained to make the cheap wood look like expensive wood.Chris1roll said:The insides of the shutters, which were nailed shut, are unpainted, presumably as they should be.
Are you sure you need to mould up the dado yourself? You might be able to find a standard moulding that would match.Chris1roll said:We will look to se if father can find some router bits to finish the dado round that corner
