A 6 way passive splitter will reduce the signal strength by a factor of 10 on each output compared to the input. This is the same as the signal strength you would get 50 miles from the transmitter (3.3 x 15miles) so I don't see this being a problem.
I would guess that any unused outputs should have a 75 ohm resistor across them but I could be wrong on that.
I guess this is possible but with a 75 ohm source, cable and load, I would have thought this unlikely.Lime said:It is also possible that the piece of coax in question is of a length that creates resonance and the tv end is a null point.
