Penners
- Suffolk, England
A fair observation. And I'm very impressed that your budget sander had withstood 18 months of daily use.
To be fair I only did a couple of online searches and those prices are a bit higher than you often get charged in person.Andrew Bodenham said:AMc,
Your hire shop is ripping you off if they want £60 for a belt sander. HSS only want £40 for a week long hire; my local hire shop would be about 2/3 of that. So maybe hiring would be the best option after all.
For floors I'd recommend a 4" wide sander, rather than the more common 3" models. Quicker, and more likely to leave a flat surface. It all depends on budget of course, but I've never regretted spending a bit more for a well made power tool. My Makita one goes on and on, relentlessly. I'd draw the line at the Festool belt sander though, at £450 it's one for the tool fetishists.
I've got a brilliant solution to that kind of problem. It's called "a telephone", and it enables you to speak to people in shops without ever leaving your home.AMc said:I toured 4-5 hire shops looking for a rotovator in November to discover they either had none at all or had no idea when they'd have them back in stock
Yes, I can believe that. In my experience once a sanding belt is clogged with bitumen, nothing will clean it.AMc said:The belt cleaning block was able to clear the belts of dust but had no real impact on the bitumen.
Really? Please can you explain a few more details. Do I have to run the belt sander at normal speed but sanding a scrunched-up bag? Doesn't it get caught around the belt and pulled into the machine? Does it have to be real polythene, or can I use a Morrisons type carrier bag?Penners said:When that's worn out, instead of spending money on another try cleaning your belt with a scrunched-up polythene bag. It works (and is free!)
Just run your belt sander at top speed and press the scrunched up poly bag against the belt. As I said above, be careful that you don't sand your fingers - this tends to leave sludgey red stains on the belt. :x Wear work gloves!Me! said:Really? Please can you explain a few more details. Do I have to run the belt sander at normal speed but sanding a scrunched-up bag? ....I'm intrigued.Penners said:When that's worn out, instead of spending money on another try cleaning your belt with a scrunched-up polythene bag. It works (and is free!)
Thank you. Except I'm going to have to go and sand something now this weekend, just so I can clog a belt up, ..... just so I can try cleaning it!Penners said:Just run your belt sander at top speed and press the scrunched up poly bag against the belt. As I said above, be careful that you don't sand your fingers - this tends to leave sludgey red stains on the belt. :x Wear work gloves!
