Feltwell
- Shropshire, England
As is so often the case, it's the bits of Feltwell Towers that have been messed about with in the past that are causing problems now.
Our "front" door is actually on the side of the house, in a flat roofed porch structure, original to the house. There are very clear signs of damp inside the porch, at the wall/ceiling junction above the door.
And this is the porch parapet from above:-
The whole top section has been rebuilt in the past, not particularly well. The flat roof inside the stone parapet appears to be OK, the problem I suspect is the terracota projecting string course (can't think of the proper word for it!) which is just below the top stone section.
That course has been re-laid such that the top of it slopes towards the porch - so any rain that falls on it will just puddle at the back and soak into the masonry. You can see that someone has obviously realised this and tried to put a thin fillet of cement mortar on top to give it some slope away from the wall, but that fillet has failed and is loose.
In an ideal world the top section would be re-built, but I don't want to do this for several reasons - time, cost, effort (those stones are going to be seriously heavy!) and as the whole thing has been rebuilt with cement mortar I think I'd cause too much damage taking it apart.
So, my idea was to put lead sheet on top of the terracota string course - lapping up the wall and mortared in beneath the stone top section, and rolling over the front edge of the terracota string course by a very small amount. There would be no slope on this, it would just allow the rainwater to puddle on it and evaporate off. I *was* going to be asking about soldering lead - in order to make something to go round the corners - but then Stuart45 helpfully posted up a reference to "Just Lead" on another topic, a firm I'd never heard of, who look like they pre-fabricate all kinds of lead building items - I think I'd get them to make something up.
http://justlead.co.uk/
Has anyone got any better ideas on how to solve this problem, or can anyone see any flaws in my lead idea above? Aesthetically I think it would be OK - the angle you view it from below, coupled with the projection of the string course, means that you'll hardly see it even where it does lap up the wall.
(And please ignore the grotty coach lamp with the horrendously badly done cable leading to it, yet another job on the list to take that down, it doesn't even work. And the very messy waste pipes and grotty plastic hopper and downpipe. And the windows and door that need painting. And..........
:lol: )
