Hi everybody
My wife and I are about to take a rather expensive plunge and could really do with some advice please :? . The Surveyor's report has just come back on a 200 year old yorkshire stone cottage and as expected there is penetrating and rising damp in most of the external walls and also in some of the internal ones.
Externally, the stonework appears to have been pointed with a cement based mortar. Some of the penetrating damp is due to identifiable problems on the roof and eaves, but the surveyor also believes that it is seeping through the porous stone walls which in some areas are only 9" thick. Internal walls are mainly dry-lined (in one case with asbestos sheeting!!) The previous owners have had chemical damp-proofing injected into the base of most of the walls 12 years ago - this now appears to have failed. The floors of the 2 worst affected rooms are concrete with a (partially) fitted damp membrane.
I have read the other threads about damp in old buildings and I understand the view that walls should be allowed to breath with traditional lime-based materials. However, my surveyor has recommended further chemical injections, new concrete flooring with (complete) membranes and a silicon application to the outside of the walls.
Right, here are the questions:
Why is there such a difference of opinion concerning damp treatment in old buildings ? (ie between the 'let it breath' approach versus the 'keep it out' techniques)
Should the fact that this building has already had 'modern' techniques applied (albeit unsuccessfully) affect my approach to solving the problems? Can I switch to 'old' techniques?
If I re-point externally with lime-based materials, should I do it all in one go or only when patches need to be repaired?
How much is a limecrete flooring? Are there any cheaper alternatives to a breathing floor?
Grateful for your help...stress levels have risen since the report arrived :shock: !!!
Rob
Rob
