Flyfisher
- Norfolk, UK
Once again, I've been overlooked.
The system only supports the Status Quo.
biffvernon said:The solution is simple. We have to change what we do. A lot.
Nonsense. If you really think it's all so simple then I rather suspect you don't understand the problem. Did you learn nothing from the Copenhagen farce?biffvernon said:The problem is simple. The solution is simple.
But that's precisely the issue; "Do not burn coal" can't be isolated and dealt with, so all the other problems won't fall away to be tackled at leisure. It's cloud-cuckoo-land thinking. You may as well wish for the faeries to fix the problem.biffvernon said:But if you can identify one humongously big factor behind all the clutter, isolate it and deal with it, all the other problems fall away and can be tackled at leisure.
biffvernon said:What you are doing is looking at hard questions, like how do politicians enact a policy that achieves the solution without immediately losing office and/or triggering mass unrest and worse around the globe. That may be such a hard problem it will turn out to be impossible, in which case our species' days are numbered.
Hell, no. I glossed over the political and sociological issues above, because (a) Flyfisher touched on them, and (b) I can't begin the imagine what they will be, in any terms other than utterly disastrous.biffvernon said:stopping using coal is the one simple thing to really concentrate on. Don't think for a moment that simple means easy.
Flyfisher said:but absolutely nothing about 'no coal' - it's completely untenable.
The Government of British Columbia?Flyfisher said:OK, I should have written "absolutely nothing about 'no coal' that anyone is taking seriously".
That's a curious comment. Where do Lovelock and Hansen disagree? I rather suspect that much of Lovelock's work must be based on the science that Hansen and his colleagues have done. Lovelock himself made a couple of very important contributions to climate science, a way of thinking about the planet and a technology for detecting trace quantities of gases, but the observational data has come from Hansen's team.Flyfisher said:I'm currently reading Hanson's book. So far, I think Lovelock has a better grasp about how things are going to play out and what we can be doing. At least Lovelock seems to be grounded in reality.
From what I've read, Lovelock seems to be advocating that we focus on adapting to inevitable climate change whereas Hanson seems to be chasing a dream of getting back to 350ppm by "simply" not burning coal reserves and removing CO2 from the atmosphere.biffvernon said:Where do Lovelock and Hansen disagree?
Lovelock certainly is suggesting that.Flyfisher said:I don't think Lovelock is suggesting "that a few people may eke out an existence near the pole if they're lucky"....The climate will undoubtedly change and we'll undoubtedly adapt.
