Penners
- Suffolk, England
Scubtstu - on your general point about things going wrong during work on a listed building, it all depends on what you mean by "wrong".
If you embark upon a project to restore/renovate/repair - call it what you will - a period property, you really need to know what you're letting yourself in for. If you go into it with your eyes open, then things won't go wrong, they'll just do what you expected!
The most important thing to understand is this. Whatever problems you can see on the surface, there's always the risk that you'll find more problems beneath the surface. For example (and this is entirely fictitious, but a typical example) you might set about repairing a rotted door frame. This exposes a dodgy connection to a light switch. Tracing this exposes some old, deteriorated wiring; renewing this brings to light a rotted ceiling joist... and so on.
This description is not meant to terrify you. It's simply meant to underline the general principle that - whatever you budget in time and money for your renovation - you should mentally double it. That way you shouldn't have any nasty shocks when your spending target and time target both overshoot.
But as I said above, if you have no experience of this type of project, I do urge you to get expert advice from a surveyor who has really good experience in period properties of your type. Ask for a full survey of the building, and a list if the main items that need addressing. You can also ask the surveyor to give you a general idea of what the work is going to cost.
Don't go on the say-so of an estate agent.
