biffvernon said:The gas in aerogels is air. The clue is in the name.
OK. I took the name as being a reference to aerospace technology - I've obviously been reading too much marketing blurb.
I thought pentane was a liquid.biffvernon said:The PUR and PIR foam boards are inflated with something other than air, such as pentane.
 I hope it has all leaked out long before it gets anywhere near me, pentane is highly flammable with a flash point of -49C!biffvernon said:The PUR and PIR foam boards are inflated with something other than air, such as pentane. This insulates better than air but it is unclear how much of it will have leaked out and been replaced by air after a few decades.
That's not as strange as it sounds though, just think of petrol as an example. If you have a bucket of petrol at room temperature it doesn't boil, but it you light it (and please don't try this at home children!) it certainly burns. See - http://en.wikipedia.org/wiki/Flash_point and http://en.wikipedia.org/wiki/Autoignition_temperaturePenners said:Hmmm - boiling point of 36.1C, flash point of -49C. This strange substance apparently combusts some 85 degrees colder than it boils! :?
Yes - it burns because the ignition source ( ie: your match or whatever) is raising its temperature to its flash point. It isn't igniting at room temperature.Me! said:That's not as strange as it sounds though, just think of petrol as an example. If you have a bucket of petrol at room temperature it doesn't boil, but it you light it (and please don't try this at home children!) it certainly burns.Penners said:Hmmm - boiling point of 36.1C, flash point of -49C. This strange substance apparently combusts some 85 degrees colder than it boils! :?
Pentane has replaced CFCs in insulation because it is much less damaging. (Not that I'm keen on anything that can't be grown, like sheep's wool.)citizensmith said:I can imagine similar problems like there were with CFCs escaping from old fridges when their blown insulation was exposed when being scrapped.
Yes I agree completely. I wasn't suggesting that it was ever going to spontaneously combust, just that based on the data quoted previously that there would be sufficient flammable vapour available at room temperature for it to be ignited by a spark from a switch, a candle flame or an open fire. I understand what Biff says about it possibly being safe by being contained in cells, but I'm not convinced I want to risk it. Are there any chemists or physicists out there who can explain why I have completely got the wrong idea, and that it is actually completely safe?Penners said:It isn't igniting at room temperature.
MdB said:You can't go below absolute zero as you "kana break the laws of physics, Jim" but absolute zero itself is fine (which is here by the way so Newcastle is above absolute zero)Johneds said:So if we stay below absolute zero, say like in Newcastle, we're allright then?MdB said:If a substance has a temperature above absolute zero
Rob said:Thanks for your replies.
I have started to look through the 148 pages of text on the greenbuilding forum with much interest. It appears that depending on how you test it, and under what conditions you can prove it either way!
What I am concerned with is less of the politics and physics, but the practicalities. Has anyone out there ever fitted this stuff to their own house? (ie they were around for a significant period after to judge the results).
On paper this looks to be the ideal solution to my problem, and I am confident I can fit it in the correct manner, so would really like some first hand opinions. Anyone?
Regards
Rob
