Flyfisher
- Norfolk, UK
michael said:Could these polystyrene rafter insulation boards be a possible solution to my loft condensation problem?
http://www.wickes.co.uk/polystyrene-rafter-insulation-boards-pk3/invt/210020/
As one reviewer states: - “The panels have a series of very deep slots running along their length that are cut to match the panel to the width of the rafters. The remaining slots provide compressibility so the panel can be squeezed concertina-like between the rafters and the tension induced holds the panel firmly in place. No tape, glue. tacks or anything else required. A clever, neat, simple and effective design.”
It seems to me that with these panels ‘tightly’ installed between the rafters, there would be no cold slate or roofing felt surface for condensation to form on?
I don't think so.
Presumably your attic is not heated, in which case what will any insulation achieve? All it can do is slow down the speed at which the attic air temperature will equalise with the outside air temperature. Without an internal source of heat the attic cannot remain at a higher temperature than the outside air for very long. Also, consider what will happen when the outside air temperature rises. That same insulation will keep the attic temperature cooler for a while, leading to the possibility of condensation, even on warm, humid summer days.
If your ceilings are so 'leaky' that a significant amount of humid air is escaping into the attic then I suppose that good insulation might help to trap that escaped heat and help to keep the attic warm and might therefore reduce condensation, but I suspect you're not really trying to create a warm attic space.
Instead of insulation, vapour barriers and the like, all you really need is effective ventilation to allow humid air to escape. This won't require a howling gale through the attic, just a gentle and barely perceptible trickle of fresh air.
Also . . . .
michael said:It seems to me that with these panels ‘tightly’ installed between the rafters, there would be no cold slate or roofing felt surface for condensation to form on?
Beware of being fooled by 'cold' surfaces. The roof slates will undoubtedly feel colder to the touch than the wood rafters but think about why this should be. How could the wood actually be warmer than the slates in the absence of any form of heating if they are both in the same ambient temperature? The reason, of course, is that our fingers are warmer than both so when we touch them heat is drawn away from our finger and we feel that as a cool sensation. The faster the heat is drawn away, the cooler the surface 'feels'.
Put a wooden-handled hammer in your fridge overnight. In the morning hold it by the handle and also by the metal head. They will feel completely different, even though both the wood and head must be the same temperature.
