Is listed building consent, planning permission or building regs permission required to install air bricks on a grade 2 listed property? In my case two or three air bricks might be the way of allowing sufficient ventilation into a ‘lean to’ loft space which continues to suffer badly from condensation. Being on the side of a hill, the air bricks would be visible to the public on the other side of the wall that the roof is leaning against and would be located about head height to passersby albeit the foot traffic in this residential street is quite minimal.
There are no options for ventilation through the walls at either end of the 'lean to' roof as these would open up into occupied indoor spaces, one end of which is a party wall into my neighbor’s house.
The early 19th century design of this lean to roof doesn’t unfortunately allow eaves or soffit vents to be effectively installed and the tile (slate) vents currently installed also seem to be quite ineffective.
I looked at the loft insulation late last summer and doubled up on the thickness and blocked up any areas where I thought there might be warm air leakage into the loft but to no avail. Dripping rafters, dripping roofing felt and sodden loft insulation always returns at this time of year so I’m hoping overkill on the ventilation with air bricks through the wall that the roof is leaning against might solve the problem.
I suppose another alternative could be a wall mounted dehumidifier installed in the loft space but I'm wondering if the dripping condensation would make this an electrical/fire hazard? Does anybody know how to select the correct sized dehumidifier against the space to be dehumidified i.e. liters per day or however they’re sized? This also seems like quite an expensive option so the air brick solution would be preferable if there’s no LBC/planning complications.
