We recently had a building survey carried out on a Victorian maisonette and were advised that lintels, joist ends and wall plates should be further examined. How do you further examine lintels, joist ends and wall plates before buying the property? Surely this would be invasive and require decorative repair afterwards. If a lintel needs replacing what would be the likely cost?
The following recommendations were copied from the survey.
(1)“The current owner has undertaken a general refurbishment of the building and a specific enquiry should be made as to whether timber lintels were exposed for examination and treated or repaired as necessary. If they have not been inspected, this is a potential area for further examination at some stage in the future. The cost implication of removal of decayed lintels would be considerable, and ideally further examination should be undertaken sooner rather than later in order that you may have the opportunity of renegotiation of the purchase price should such defects be identified.
We are particularly concerned with the possible risk of dry rot affecting the timber lintels and extending to other elements of construction.”
(2)“It would appear that a decay problem has existed in the past, given that there is evidence of repaired floors and renewal of skirting boards. We would anticipate that there may be a decay problem to joist ends, wall plates and timber lintels. Any original structural timbers would not have been pre treated, and are therefore vulnerable for possible decay problems.
If no guarantees exist for general timber treatment throughout the building, we would recommend that this is put in hand. We would also recommend, if possible, some further examination of joist ends, wall plates and lintels to assess existing condition.”
Thanking you,
Gemma
Thanking you,
Gemma
