Inspector John
Last year I did a 2 day course on lime. I didn't realise that lime came in different strengths (up to cement itself)
I now understand why it's better to use lime rather that cement on certain types of construction.
However I can understand why we builders use cement in cases like this bad weather.
Where you have to wait for a window of opportunity to use lime and the long length of time it takes for lime to set and the worry of the lime dying due to low temps & frost.
I'm on a external rendering job in Gloucestershire and although I've put a dubbing coat on It's been nearly 2 months since then and although I like the merits of lime mortar I find it a real headache worrying about whether the dubbing will blow off as opposed to cement render where the worry would be movement and cracking.
It would be good in the future if I could get some internal work ready for the winter months but it never works out that way
I would have finished the job by now if I used cement but I also know the job would not be right
With the market as it is for builders is not improving I'm getting to the point where I may call it a day and take up something else or leave this islands altogether
