Bluesky32
- East Yorkshire
I wonder if anyone has any advice on using lime. We are renovating a 200 year old brick cottage and we have stripped back our internal walls to the brick after removing layers of plaster and cement! Our builder has recommended using a pva coating and plaster to combat any exisitng damp (the damp is mostly condensation and a leaking chimney which needs repointing) where as I was advised by our damp and timber surveyor that it would be better to use lime to allow the walls to 'breathe'? Also if we do use lime how do we find out the best mix to use for both the plaster and the external pointing? Should I look to use a specialist plasterer? So many question!
