The Smeaton Project, a research programme commenced by English Heritage indicates that a 1:1:6 mix, containing a 50 per cent cement binder, is unlikely to segregate, while a 1:2:9 mix, containing a 33 per cent cement binder, is almost certainly at risk. Until recently it was considered good practice to gauge lime mortars with as little as 5 per cent cement, just enough to impart a chemical set but not enough to make the mortar appreciably harder. However all of the Smeaton Project test samples containing less than 25 per cent failed.
OddJob said:You quoted this article,6:1:1 mixes are fine if you want a strong mix but 3:1 lime mixes with a couple of handfuls of cement are a bad idea as the cement clumps making the mix weaker than without it. How do I know this? well somebody has tested it and the results are published.
http://www.buildingconservation.com/articles/cement/cement.htm
I remember it well and the project,check the date,it was 15 years ago,1995,the year I started in lime,within a year opinions were changing and have changed several times since,and the opinion is now very firmly against any gauging with cement.
Around the same time there were debates about gauging putty mortar with hydraulic or vice versa,now gauging putty and hydraulic is perfectly acceptable,putty as a plasticiser in hydraulic mortar or hydraulic in a putty mortar as a setting agent.
This has come about by people who actually use the stuff day in day out,not people who sit behind a desk working out equasions and producing articles based on assumptions.
NHL limes are classified according to Compressive Strength expressed in N/mm2 measured @ 28 day in mortars prepared with a 1:1 binder/sand ratio as defined by EN 459.
http://www.stastier.co.uk/nhl/info/eunorm.htm
Hydraulic limes compressive strength and setting ability still comes from it's various impurities.
Read the Holmes/Wingate book and you will see how it was used in building major canals.
:wink:
I was able to follow your 2LAs, TLAs and FLAs - YMMV. OTOH if you have problems you can JFGI.Gervase said:Bloody hell, with all those acronyms, I'm beginning to sound like a chairborne tosser!
I've not heard of that one before but I'm assuming it's in the same vein as RTFM :lol:MdB said:JFGI
OddJob said:Your CO should know better,9:3:1 is a mix that was bandied about for years and it's now generally agreed it's wrong,no serious lime practicioner would use it or advise its use.
It's a cementicious mortar not a lime mortar,cement in itself is not strictly a pozzolan,a pozzolanic cement is lime with burnt material such as fly ash etc.
It's completely wrong and unnecessary to use cement anywhere on a lime structure.
Not according to wikipedia: http://en.wikipedia.org/wiki/White_Portland_cementSchoolmarm said:What about the white cement that Flyfisher said was specified? Isn't that different?
Ff,looks like all your questions have been answered and I can't add anything to those replies.Flyfisher said:Just to clarify, the 9:3:1 mix was specified only for new work and not as a repair mortar. It was used to rebuild the top 1m of a chimney and for bedding the ridge tiles. Isn't that consistent with your earlier comments about not using hydrate on a roof?
Ridge tiles may not desperately need a breathable mortar in most cases,it depends what's underneath and I can't claim to be any kind of expert on roofing,but a failed cement mortar allowing water ingress would trap water and could rot the ridge board.I don't see why ridge tiles need to be bedded with a breathable mortar and, as OddJob pointed out, a "harder" mix would be more suitable for roof applications anyway.
I see your point about the rebuild being a repair. I presume the LBC interpretation was that the rebuild was completely new - a bit like the new work bedding the ridge tiles perhaps? I've added some photos showing the before and after. You're right about it sitting on top of the existing chimney, but any new work has to abut original fabric at some point. A "repair mortar" has not yet been specified for the others works covered by the LBC, but it's a condition of the LBC that agreement is required before work commences. I've not yet started on those bits.OddJob said:But forgive me,rebuilding the top 1m of a chimney constitutes a repair and not new work surely,you're still building on top of the old work,it begs the question what on earth did he specify as a repair mortar?
. . . which had happened in some places; notably where previous repairs had been done with a rock hard cement mix! When repairing the roof, I wrapped the breather membrane over the ridge board so, hopefully, water ingress should not cause similar problems in the future - well, in my future anyway.OddJob said:Ridge tiles may not desperately need a breathable mortar in most cases,it depends what's underneath and I can't claim to be any kind of expert on roofing,but a failed cement mortar allowing water ingress would trap water and could rot the ridge board.
Fair points, which is why I assumed a weak cementitious mix would be suitable.OddJob said:By harder mortar for bedding ridge tiles I mean more durable,hence NHL or a pozzolanic mortar.
Plus what you're not taking into account is the natural movement of the building,again hence NHL or a pozzolanic mortar.
No, no, no. I was questioning your points in a genuine sense, to better understand the subject. I apologise if my posts came across as being contrary, that was not the intention at all. Heck, I've only got a few years of this building/repairing lark under my belt and consider myself a rank amateur compared with many of the people here who have worked on old buildings all their lives, but I find that asking loads of questions is a good way to learn - especially with a subject that seems to elicit widely varying answers. I can see why many regard lime as an 'art', which is all very well, but it can be frustrating when I'm in the middle of it and just want to do the best for an old building.OddJob said:In case you're trying to pick holes in my arguments![]()
It ain't me that has to get up on the roof and repair them :wink:
That was said entirely in jest old chap,hence the smilies,meaning literally it ain't me who has to get up there and fix it!OddJob wrote:
More artisan than art.I can see why many regard lime as an 'art'
