A new thread to carry on the discussion from this thread:
http://www.periodproperty.co.uk/forum/viewtopic.php?f=1&t=11156
Worth reading.
If I buy a new bag of hydrate and use only half straight away then the other half will be unusable a year later. If it is turned into putty though and kept damp, carbon dioxide can't get to the putty so it will keep. What have I got wrong here? (and it isn't just me - nobody on this site as corrected me on this before)
http://www.stastier.co.uk/nhl/info/eunorm.htm
There - you have learnt something today. Now can you please teach me where I'm going wrong.
I'll see if I can borrow a copy. Thanks for the link.OddJob said:Okay,let's try and start from the top but chances are I'll answer the questions not in order,I do suggest you read this though.
http://www.amazon.co.uk/Building-Lime-Introduction-Stafford-Holmes/dp/1853395471
Too true, hence my caveat.OddJob said:That's the excuse used by people who have either never used lime or don't want to,they've only used cement and it works perfectly well for them and gets the job done.it always has been and all my mates in the trade do it that way as well and nothing has fallen down yet
http://www.buildingconservation.com/articles/cement/cement.htmOddJob said:I'd recheck that if I were you,published where exactly?6:1:1 mixes are fine if you want a strong mix but 3:1 lime mixes with a couple of handfuls of cement are a bad idea as the cement clumps making the mix weaker than without it. How do I know this? well somebody has tested it and the results are published.
And who tested it?
Wasn't that Tommy off the telly was it :roll:
April fools day is long gone mate!
Worth reading.
You have missed the point. The hydrate I have is 93%(minimum) active lime. If this has reduced to say 90% after sitting in the bag for 3 months due to the carbon dioxide that has leaked inside the bag then this will make no difference at all to the quality of the lime mortar made from it. If it instead goes to 50% active lime after one week then this is significant and a good reason not to use hydrate. The manufacturers claim otherwise though.OddJob said:I thought I explained that,you obviously weren't paying attention.I agree with you here, (apart from the lumps which I've never noticed) however, the question is "how quickly does it carbonate in the bag?" I do not know the answer to this (and would be interested in knowing it) blue circle give a lifetime of 3 months+ for their hydrate and I know that my local builders merchants gets a new pallet of hydrate every two weeks. I would therefore expect a bag of hydrate used within a month to have very similar active lime levels to that of putty. Any unused lime should be converted into putty of course for it to keep. Exactly the same process applies to NHL limes which will also carbonate in the bag. Some lime producers state that they will keep for 1 year in the bag so again the process must be slow.
From this, I conclude that there is no technical reason not to use hydrate. In my very limited experience have also not noticed any difference in workability between hydrate and putty and as hydrate is cheaper, unless given a good reason not to, I will continue to use it. I very much welcome comments on this.
As soon as it's hydrated.
The manufacturers of hydrate and NHL state that it should keep in the bag for 3 months+. You seem happy to use NHL so why not hydrate? As far as I can make out, NHL is very similar to hydrate apart from the additional chemicals in NHL. Both will carbonate in the bag I believe so why the different attitude to them?OddJob said:You choose who you want to believe,a builders merchant who sells cement and the salary men at Blue Circle,neither of whom would know how to use lime if it climbed up their company uniform trousers and bit them on the nadgers.
Or a lime practicioner.
Your choice.
Laugh at me all you want, I don't mind but please let me know why you are laughing so that I can learn.OddJob said::lol: ;Iunused lime should be converted into putty of course for it to keep
I think I just broke some ribs laughing.
NHL limes are classified according to Compressive Strength expressed in N/mm2 measured @ 28 day in mortars prepared with a 1:1 binder/sand ratio as defined by EN 459.OddJob said:Yes NHL 5 is stronger than NHL 2,eminently versus feebly hydraulic,with NHL 3.5 being moderately hydraulic.I, like most people here I guess, would have said that NHL 5 is stronger than NHL 2 (indeed the number refers to its compressive strength
But no,the numbers do not apply to its compressive strength.
They refer to the natural impurities in the lime,i.e. clay that aids setting.
