Hi,
Looking for some help finding some half respectable lights. Prior to Christmas we're doing a quick refurb of our acid green dining room , which comes with four single spotlights mounted one in each corner. Thanks, PO!
It's a highly ornate lincrusta ceiling (thankfully not acid green!) and as part of this quick refurb all I can afford to do time wise is replace like for like. It's quite delicate and I daren't risk adding a central fitting until it's been stabilised properly. We are pretty much only changing the paint colour and hopefully sorting these light out somewhat.
The current lights are full size fittings, in white plastic and metal, quite awful especially since half of them have broken at the plastic joint.
Anyway, I am loooking for a fairly drop in replacement and would like to keep the bulb size as I have lifx bulbs in them which arent cheap to replace. (The bulbs are also quite long, for what it's worth, so I don't think an armoured type fitting will work).
As you might expect it seems the world has moved on since these were fitted, and most spots appear to be gu10 size.
Any suggestions for single spots using a full size bayonet (b22) or screw (e27) would be most welcome!
