That seems a bit fake. I follow GK's method except I work on the lawn when hammering the nails through. Haven't skewered a worm yet. When you come to bend the nail over (clinching) it helps to have the door on a hard surface (move to concrete drive) so you don't accidentally push the nail back from whence it came. If you can tap the tip over first and then the rest of the nail the sharp tip buries itself in the wood instead of snagging your best pashmina shawl.Phase1 said:, the standard new construction seems to be: screw the battens in, plug the holes with dowels of same wood, hammer roseheads in the planked face along the lines of the battens for additional strength/effect.
Well, that's an expression I've heard and used many times before, and I never had any idea where it came from.mike said:'dead as a doornail'
ball catch with a latch handle without the sneck
