Penners
- Suffolk, England
The trick is to shoot in RAW format. With the right software (Photoshop, for example) you can then muck about with the white balance setting (and a host of other things) after the shot has been taken. It's not quite as effective as getting your white balance right pre-shot, but it's not far off.AMc said:Digital cameras and camcorders have auto and manual white balance settings for each that adjusts what the sensor records as pure white in each circumstance. If you set your white balance to "tungsten" and take a picture outside it will have a heavy blue cast - if you set the camera to outdoor and use it without flash under tungsten lights you get a very orange cast.
