JanieB
- Oxfordshire
At last after 12 years since the original plans were drawn up, my house is being renovated starting with rebuilding the kitchen extension. The work started last Monday with the digging up of the old concrete floor of my conservatory. The removal of the concrete went further out as the building inspector's preferred option was to move the inspection lid for the soil pipe to one side of the new extension. It proved to be a non-starter as there were too many other services all in the same place, so I'm going to have to have a sealed lid in the kitchen.
However, the excavations found a leak from the main water pipe that serves 4 houses in the terrace (once 5 but 2 have been combined into 1). I called Thames Water who insisted there was no leak as there was no movement on their meter in the pavement. I pointed out that my (late) neighbour had called them out several times over the years as she was positive there was a leak. To add to this, this time he could actually see that the pipe was leaking. The meter was installed about 12 years ago as a direct result of my neighbours reports.
He asked if any of my neighbours could be using any water but they were all at work. So he turned on some taps in the house and the meter still didn't move. He changed the meter, turned off all the taps and well, what do you know, the old meter was faulty. We have a leak, and not the one we can see, that is losing water at 2 litres an hour. :shock:
This has been going on for at least 15 years, not that I think the leak has been that bad for all that time. A bonus is that they are treating it as an emergency and regard it as their responsibility as their meter was faulty.
They'll be back tomorrow to fix it. It probably means digging up the ginnel but at least myself and my immediate neighbour may have dry houses and be able to replaster the walls without them blowing.
