Feltwell
- Shropshire, England
Yes, that secondary glazing panel is easy to remove, though it is quite heavy. It's a non-opening window so apart from the occasional clean it doesn't need to be removed, I just leave it in place all year round.
If you're putting in new frames I'm sure a good joiner could make them even more unobtrusive if the secondary glazing was designed in as an original part of the frame.
Couple of points to bear in mind though:-
- You'd have to convince Building Control that what you're doing gives sufficient insulation for the regs, and that you are maintaining background ventilation. Others on this forum are much more knowledgeable than me on this! Bear in mind that your local BCO may well be used to just seeing UPVC with trickle vents. I have to say though that my BCO here is a nice bloke and very pragmatic, he's quite open to alternative ideas.
- Escape in the event of a fire. Don't compromise your escape routes by fitting glazing that is hard to remove.
