overlander matt
We recently put in an application for listed building consent for work on our Georgian house. One of the things we would like to do is to replace a lot of the damaged bricks on the front of the house (and elsewhere) and put right some particularly poor quality repairs. In total, I have estimated around 240 bricks need replacing and mainly at a higher level which requires scaffolding. As we have a few repairs to do up top to the cornice, leadwork and roof then I am keen to take advantage of the scaffold for as much work as possible.
The house has previously been repointed with cement based mortar which may be responsible for some of the damage to the brickwork. As we have the scaffold I would be keen to see if we can repoint the entire front of the house... If not then at least the very highest section which would not be possible to reach in future without a proper scaffold. I have been asked by the new CO to provide a justification for this and to prepare a trial panel for inspection. It seems there is a reluctance to approve repointing of whole elevations due to damage this will most likely cause to the brickwork... I'm not sure what is the greater evil - the cement or the repair work.
On the plus side, the cement mortar looks fairly old on this elevation and is not very deep. It seems that it can be removed without too much effort and could even avoid the use of the dreaded angle grinder (amusingly the listed barn currently under conversion next door is covered with tell tale angle grinder dust patterns). I was going to suggest that we use a repair section as the trial panel - we have reclaimed bricks that look a decent match but will need to specify a suitable lime mortar. I like the idea of the consistency we will get from a premixed mortar but it is difficult to know what the right one is given the absence of original mortar on the front (and other elevations). I did manage to uncover a couple of areas that show the colour and pointing style but this was at the rear of the property.
I was going to try out a Lime Green product supposedly for finer joints... The pointing looks to have a ruled line between the bricks (not sure what that is called).
https://www.lincolnshirelime.co.uk/lime-green-chalk-coloured-lime-mortar-nhl-35-25kg-for-fine-sized-joints-3544-p.asp
If anyone has any suggestions on the above plan that would be much appreciated.
Thanks,
Matt
Thanks,
Matt
