Nigel Watts
- London N7
I recently had a fascinating chat with the plumber who was flushing out my heating system.
He told me that the way to keep the gas bill down in the winter was to keep the central heating and hot water systems on 24 hours a day with both the boiler and house thermostats turned up high, with each room regulated by the thermostatic valves on the radiators.
His argument was that gas boilers are at their least efficient when taking the circulating water from cold to hot and that one should instead ensure that the circulating water is constantly kept hot, with the boiler only switching on to top it up.
Despite learning about thermodynamics at University, I can't quite see this. The overall heat loss from the non-boiler part of the system will clearly be greater if the system is kept constantly hot, and why should the boiler be any less efficient when taking the temperature up from hot to very hot than it is when taking it from cold to hot?
Before you ask, no the plumber was not from British Gas.
