I did think about it but my batyhroom is behind that wall and i would have to remove some original/old lath to do it anyway so that option had everything stacked against it.DWB said:Will you bring it back into use?
Pford75 said:If the works are really inappropriate for a listed building, they won't be given LBC.
philpjuk100 said:Being listed is no bed of roses either! our old boiler died,leaking ,obsolete,it was over 30 years old and spares were not available so a new one was needed,we had no heat,hot water,shower etc,so I contacted the planning dept as the large stainless balanced flue would need to be replaced with a small plastic condensing boiler flue (the only type of boiler now allowed) the duty planner asked for pics of the current flue,drawings of the replacement flue and a pic of the flue from the brochure,these were sent.Five weeks later there was still no decision,the new boiler was fitted and I gutted the original flue and fitted it over the new one against the advice of the "gas safe" man.This done we were contacted by the CO to say we did not require an LBC but any bricks replaced needed lime mortar (I had already used this) even though the house had been pointed with cement mortar.I would like to remove the cement and repoint with lime but expect I will need permission to do this as well,phil.
I can't see where the "no bed of roses" problem is in this saga?
Pford75 said:I can't see where the "no bed of roses" problem is in this saga?
Perhaps it was the 5 weeks with no heating or hot water whilst everyone was deciding that no consent was required?
