Zebra
- St Albans, Hertfordshire
I have a timber framed house some 300 or so years old. Would it be OK to treat the timber frame with teak oil or linseed oil?
I've done some research that suggests that breathable walls work best when the most vapour permeable layers are on the outside, and the inner layers need to be about five times as vapour resistive, although still vapour permeable. I can post the link if anyone's interested.
I am planning to expose the larger beams on the inside, but use perhaps a heavier duty plasterboard to improve acoustic performance of the wall. But this would mean that the most vapour permeable part of the wall would be the exposed frame, so any moisture travelling outward through the wall could get funneled through the most vapour permeable bit i.e. the frame.
Unless I made it less vapour permeable?
I was involved in building a green oak framed building a couple of years ago, and we slathered it in teak oil. Would this be ok to treat the beams I'm planning to expose with teak oil?
