Hydraulic and Fat are different@thebadger7 what county are you based in?
@CarolineTheChemist - we have cement repointing which we want to rectify. How expensive is that process? Did they replace it with traditional fat lime mortar (hydraulic)?
Whoops. Yes they are - meant non hydraulic (I think). The lime putty I should have said.Hydraulic and Fat are different![]()
The terms are very confusing. 'NHL' stands for Natural Hydraulic lime which can set under water and doesn't involve lime putty, but theres also 'Hydrated' lime which comes in a powder and can be turned into putty with the addition of water. Some people refer to Hydrated lime as 'Non-Hydraulic' lime which easily gets confused with 'NHL'Whoops. Yes they are - meant non hydraulic (I think). The lime putty I should have said.
Ah, thanks! I was just wondering about it because I'd done loads of calculation and figured out that for the house I'm thinking about (80cm sandstone walls) it would take 12cm of wood fibre insulation to achieve the building regulation standard (get an equal or better than .30 U value).Hi, I'm no expert on stone walls, are they susceptible to freeze/thaw in the same way that a brick is? That's the main issue with brick, especially the old soft variety, if you remove some of the heat they receive in the winter with IWI and the bricks are damp then they freeze internally and the face gets blown off. I think its called 'spalding'? Then they are no longer protected from the elements.
I guess stone walls are a hell of a lot thicker too?
Depends on the density of the stone. Roughly speaking density relates to porosity and as a consequence even the hardest stone can absorb some water through its surface and spalling damage can ensue. Just not as quickly as a manufactured brick I'd guess.
Sorry for the very late reply!@thebadger7 what county are you based in?
Limestone spalls very badly due to its porous nature, worse than many bricks.Hi, I'm no expert on stone walls, are they susceptible to freeze/thaw in the same way that a brick is? That's the main issue with brick, especially the old soft variety, if you remove some of the heat they receive in the winter with IWI and the bricks are damp then they freeze internally and the face gets blown off. I think its called 'spalding'? Then they are no longer protected from the elements.
