ElectronicFur
- Monmouthshire
Yes you read that right, by design we have rain water running through two of our loft spaces in an internal open gutter.
Due to roof valleys and sky light, there are two enclosed areas on the roof which cannot drain conventionally to the external gutters. So the first valley area drains from the valley floor into a drain through the roof, which flows into an open gutter within the first loft space. This gutter then runs along the loft, turns 90 degrees, then runs under the roof,and an opening in the roof where the next valley flows into the gutter, and then the gutter carries on running into the next loft space, and out through the roof at the side of the house above the soffit and into a hopper, which is shared with the conventional gutter.
Has anyone seen such an arrangement before?
Not sure having water running through an open gutter within the loft spaces is a good idea, but at least it makes it possible to clear leaves out of it.
In addition to a proper skylight in the main stairwell, we also have an odd skylight on a landing, which is just a window in the ceiling, which actually opens and doubles as access to that particular loft space. Above it, but not directly is another window in the roof. So some light filters through. Never seen that arrangement before either.
