A
Anonymous
Guest
What you are describing Mike, in building design, is called thermal response. The dense concrete block simply absorbs more energy than the lightweight block. Take two houses; one made from solid, dense stone or block walls and another from lightweight aerated blocks. Come home when the house is cold and turn on the heating.
The dense blocks absorb a lot of the energy so the stone house takes longer to warm up. But then of course it releases the warmth for longer after the heating is turned off - the house acts like a thermal store. But of course some of that warmth is released to the outside not the inside - so you don't benefit from it all.
Now take the lightweight block house. The blocks don't absorb much energy, so the house gets warmer a lot quicker. But after the heating is turned off the house also gets cold much quicker. Although you don't waste as much energy to the outside.
So; older houses take longer to warm up but stay warmer longer. Newer houses warm up quickly but get cold quickly.
