Penners
- Suffolk, England
Not me. I'm definitely in the highly sceptical camp.
Zebra said:... the wall is surrounded by a cement floor. The bottom few courses are affected.
What would you finish the walls with so that damp didn't present a problem? At the moment, all the walls are stripped back to bare brick so there isn't a problem, up it comes and evaporates away. But I have to put some sort of internal insulation on the external walls, and won't that trap the damp against the wall, or its insulating value be affected by the damp? Won't I get tide marks on the plaster?Stephen said:it could be that there are no vulnerable materials (i.e. timber) nearby and/or it is not causing damage to decor and therefore the level of moisture is 'acceptable'
Zebra said:So nobody reckons on the electro-osmotic thingys, no?
Zebra said:Incidentally, maybe a daft question, how do you insert a physical damp proof course right the way through a solid 9" wall with the house sitting on it?
Zebra said:So perhaps where I have rising damp on bare internal walls with no render, that must mean the only remaining option is to dig up the cement floor. Hmmm. I wonder what was on the floor when the building was functioning as originally intended... And how would I make a join between a "breathable" floor and the new front extension where they are bound to put a damp membrane... Hmmm :?
We have done approximately this. The wall is considerably drier but the very base and the lime strip is still slightly damp. In our case this is due to the house being on clay and a very high water table. In this situation, no amount of evaporation is going to dry the moisture out completely. The outside ground levels are already 200mm lower than floor level but I'm going to see if this can be improved on further and do other things to lower the ground water level.Stephen said:Between the two is something I have seen used on a couple of occasions where a breathable perimeter strip is formed and/or a series of holes through the concrete that are then filled with a lime mortar mix. This avoids having to take up the whole thing, whilst creating a degree of breathability.
Matt Green said:My ex-boss has quite a bit to say about them. Not much of which is polite. Shall we say that searches for evidence that they have any effect when installed without cement render prove difficult?
Matt Green said:I would be inclined to dry line the wall keeping the battens isolated from the masonry and as far off the floor as possible.
Stephen said:I was going to suggest some form of dry lining as well as this results in a dry surface but allows the water to move through the fabric as it always has. Depending on how much damp there is you might need to consider providing a form of drainage for the water.
Stephen said:The floor is more difficult and it depends if it really is causing a problem. The range of options are - do nothing to take it up and replace. Between the two is something I have seen used on a couple of occasions where a breathable perimeter strip is formed and/or a series of holes through the concrete that are then filled with a lime mortar mix. This avoids having to take up the whole thing, whilst creating a degree of breathability.
MdB said:We have done approximately this. The wall is considerably drier but the very base and the lime strip is still slightly damp.
MdB said:We have done approximately this. The wall is considerably drier but the very base and the lime strip is still slightly damp. In our case this is due to the house being on clay and a very high water table. In this situation, no amount of evaporation is going to dry the moisture out completely.
I don't think that analogy could ever be regarded as boring. It's an excellent one and bears frequent reiteration.Flyfisher said:I've probably bored eveyone half to death with the rubber glove analogy but here goes again; put a rubber glove on your hand and within minutes it will be all sweaty and damp, yet the other hand will remain completely dry - even though it's giving off just as much moisture as the rubber-encapsulated one. If the moisture can evaporate there will be no build-up of damp
