From what we can tell, the current owners of the property we're buying did lots of work back in about 2003 including an injected DPC - including replacing the internal lime plaster with modern; treated the timbers for woodworm and death-watch beetle; repointed the whole property in cement and so on.
The DPC and the timber treatment both come with guarantees and for a fee we could have these transferred to us.
The injected DPC was to the front and one gable wall. The holes can be seen at ground level along the brickwork. The floor-level in the house is lower than this, and there is also a large cellar directly underneath.
There is some damp in the cellar, but removing vegetation along the wall where the vents are, removing all the cement pointing from the ashlar (which is causing the walls to be wet and the surface of the ashlar to start spalling) and putting in a decent ventilation system should deal with that. Otherwise, the house is pretty dry everywhere and removing the cement and repointing in lime should help that.
The surveyor's view was that there had been woodworm, death-watch beetle and a load of other beasties, but not for a very, very long time.
I have a couple of questions.
a) is there any point in paying for the guarantees to be transferred over? The beetle treatment appears to have consisted of spraying the beams with chemicals - from what I have read, it seems that getting rid of DWB is considerably harder than that.
b) is an injected dpc any use if it is put in above floor-level in a wall that has a cellar below it?
c) is an injected dpc even a good thing in the first place? Can I repair the damage? Fortunately the holes in the bricks aren't too obvious.
Thank you for any advice.
