Alex
- South East Wales
Penners, that is exactly what happens to me, its so nice to know that I am not alone in my misery
At one time the house was on land that was rented from the landowner by the local ironworks and was repeately rented by different owners of the ironworks until 1924, when for the first time, it became owner occupied. So I will have plenty of reading to do at our local archive this winter, thankyou.middi said:If your house ,when built, was part of a bigger estate you will have extreme difficulty in dating it.IF this is the case you may have some luck if you search the records of that bigger estate that it belonged provided they recorded it.
You need to make sure that you have one [/quote] for eachAlex said:What have I done ?
Name said:. Green ones good, red ones bad. The first two red ones are superfluous as there's no text between them. Obviously you don't put a space between the t and e when you do it for real!
[quot e="middi"]If your house ,when built, was part of a bigger estate you will have extreme difficulty in dating it.IF this is the case you may have some luck if you search the records of that bigger estate that it belonged provided they recorded it.[quot e][/quot e][/quot e]
At one time ........[/quot e]
