There are some products with lime in the title that also have lots of other things in them (often cement) so they aren't the best. However, the hydralime data sheet http://www.lafarge.co.uk/CementDatasheet/Hydralime.pdf gives the following:
Also:
Now lime doesn't give you anything like the strength of cement mortars so there is a danger of people using it for unsuitable building jobs where mortar strength is important. The manufacturer therefore cover their arses with statements that it isn't suitable for mortar without cement. Some do, some don't but it all the same stuff. If it is the wrong stuff then various others here and myself are using the wrong stuff too.
The only thing I think you are doing wrong is the mix. 3:1 sand:hydrate is about the same as 4.5:1 sand
utty which is rather a weak mix. I use 2:1 sand:hydrate. I am confidant that this is OK as if I mix 2 buckets of sand and 1 of hydrate, I only end up with 2 buckets of mortar. i.e. the lime has only filled the gaps between the sand with nothing spare. With 3:1 there will still be gaps between the sand grains. I wouldn't worry too much though. Its certainly not something to redo.
This exactly what you want.Hydralime is manufactured by the following method:
• Calcining limestone or chalk in a kiln at high temperature to produce quicklime.
• Hydrating (slaking) the quicklime under carefully controlled conditions to produce a fine, dry, white,
calcium hydroxide powder.
Also:
So of the bag, 95% is usable lime. Again this is exactly what you want.Available lime, as Ca(OH)2 (%) 95.0 to 97.0
