Jewsons do as probably other builders merchants. It is commonly used in 6:1:1 mixes and our local branch goes through something like 1 pallet of lime for every 10 of cement. NHL on the other hand is difficult to get hold of here.robgil said:Could be chalk in there , I wouldn't be surprised. would putty do instead of hydrate? I don't know anywhere local that sells hydrate , its all NHL round these parts.
middi said:Two parts soft sand ( not the washed type), one part sharp sand and one part hydrated lime.
Flyfisher said:It is commonly used in 6:1:1 mixes and our local branch goes through something like 1 pallet of lime for every 10 of cement. NHL on the other hand is difficult to get hold of here.
I'm glad I'm not alone!Flyfisher said:Frankly, I don't really understand the difference between lime putty and hydrated lime
I'm glad I got something right!Flyfisher said:I suspect the breathability confusion arises because, as MatthewC rightly says, lime is often used to increase the plasticity of cement mortars to make it more 'workable'.
I didn't realise thatFlyfisher said:Just add water when needed and, hey presto, lime putty!
As, I suspect, the mortar on my house was. It seems to have used a very fine sand which now crumbles where it has been subject to prolonged damp, hence the need for some re-pointingFlyfisher said:many (most?) historical mortars would have been made up from roughly shovelled portions of lime putty from a hole-in-the-ground together with sand from a nearby riverbed or perhaps just a very sandy soil - impurities and all.
Not forgetting the cinders and ash from the fire that burnt the limestone in the first place!Flyfisher said:many (most?) historical mortars would have been made up from roughly shovelled portions of lime putty from a hole-in-the-ground - impurities and all.
Prolonged storage of lime putty allows it to dissolve and re-crystallise repeatedly, which results in much finer than normal crystal sizes that enhance its plasticizing ability. In other respects it acts as dry calcium lime [hydrate].....
I think you will find that 3:1 Sand:Cement and 6:1:1 Sand:Cement:Lime will look the same apart from the colour with the 6:1:1 looking a bit lighter but not by much - Not too sure though. You may want to look into using white cement as a possible match.MatthewC said:One last question: if we use 6:1:1 for my new extension, can that produce a finish which is comparable to the lime on the existing house (so long as we can match the colour, which was the original question on this thread!), or does it give the hard-looking cement finish?
